I have a series of four nitrogen gas springs [Dadco®] mounted in a row on a plate.The springs lift two forms, two pistons per form. After approximately 200,000 compressions, one of the pistons (randomly - has happened to all four) will grow in length causing tool damage. The piston will be anywhere from .020" to .300" higher than in new condition. The pistons have more than enough room for travel without exceeding the travel limit. What could be the cause of this type of failure?
