Previous in Forum: Wind Loads on a Flat Panel with Different Aspect Ratios and at Various Angles?   Next in Forum: Venturi Orifice Steam Traps
The Adiabatic Temperature (deg F) equation
03/20/2008 12:56 AM
Please let me know What is the Adiabatic Temperature (deg F) equation?
Thanks & Rgds,
Guest
Good Answers: 53
Re: The Adiabatic Temperature (deg F) equation
03/20/2008 1:41 AM
03/22/2008 11:18 PM
Adiabatic temperature rise, which is what you are looking for, is published by each air compressor manufacturer, as it relates to their compressor. Don't try to mini manage a system, you will grow old very fast.
I take it you are having heat problems coming out of the compressor. They make coolers to solve that equation for you. IF the compressor was bought new, all the factors relating to its performance were calculated in, and the proper cooler was designed to handle it.
