Previous in Forum: Batteries   Next in Forum: Electromagnetic Analysis for SR Motor
WAP(Wireless Access Point)
03/20/2008 1:40 AM
Dear Sir,
While designing ELV consisting CCTV and Data access systems .. what considerations to be taken to install WAP's and what distances should be maintained for multi storey hotel . with restaurants ballrooms and guest rooms.
thanks and regards
Patrick.g
Nigeria - Member -  Member
Re: WAP(Wireless Access Point)
03/21/2008 7:12 AM
Your consideration while installing WAPs, among other things;
1. Coverage area of Assess point equipment.
2. Since you are installing in a multistorey building, consider spacing between APs in same storey rather than between storeys. Having determined the coverage area, space them such that the coverage areas overlap to make for seamless mobility (no disconnection of service while moving from one point to another)
Same holds for APs between storeys
3. Consider you structured office cabling and determine the quallity of cable to use. This should be a function of your estimated network data thruput. Consider between UTP cat 6 and 7 to eliminate the possibility of upgrade in near future.
4. Of course number of users is important.
5. Intergrity of the power system MUST be established prior to istallation.
Cheers,
ethobil
Join us to make the world a better place: Propergate peace.
