Previous in Forum: Life's Inspirations   Next in Forum: Gravitational Constant
ARM CPU Required
03/21/2008 8:13 AM
Hi,
I am into development of Layer 2 Managed Ethernet Switch. I am looking for ARM cpu to integrate it with Network Switch Chips provided by Marvell/ Broadcom/ VIA, etc. Kindly suggest me the ARM cpu that can be interfaced with the chips mentioned below to make my solution work.
Marvell: 88E6083/88E6065/88E6063
Broadcom: BCM5325M/BCM5327M/BCM5338M/BCM5328M Sanjeet
Re: ARM CPU Required
03/26/2008 1:52 AM
so much arm products for selection on the market now.
arm7, 9 ,10 etc core add verious interface.
search fro google or such engines.
03/26/2008 4:09 AM
Hi,
Thanks for your reply. I have searched the CPU's but nobody gave the details/design that it can be integrated with Marvell Switch Chips. Marvell provides MII interface to interface external CPU.
Kindly suggest some 6/8/10/12 port Network Switch Controllers with integrated ARM cpu or provide the details of external ARM cpu to integrate with switch chips.
Sanjeet
03/26/2008 5:51 AM
you requirement is too fractionaze. Im afraid its out of my depth. I hvnt do such work.
if you need arm I can buy for you on our market from 7 to 10.
your topic will be suggested to cisco web site for solution. and Im aftraid you will need fpal etc chip.
sorry.
Register to Reply 3 comments
You might be interested in: CPU Chips, CPU Cards and Modules, CPU Fans and Coolers
