We built a generator that runs at 430kHz. We have been able to meet the FCC requirement for noise feeding back into the supply lines except at the 430kHz range. Moving the Corcom line filter so that it protrudes out of the back of the generator lowers the noise in the 430 range to acceptable levels. Corcom does not offer this filter with IEC connector as an option and the model they do offer doesn't seem to work quit well enough.
My question is this: Does anyone know of a filter or network that I use in conjunction with the corcom filter to target the 430kHz range.
Is there an RC network or filter circuit that I could build myself?
Thank you in advance for your responses.
