Previous in Forum: enquiry   Next in Forum: API 5L Grades for Pipes
Flexible Joint for a 200mm Dia Pipe
03/25/2008 5:43 AM
I am looking for a flexible joint for a 200mm dia pipe which will allow me about 100mm movement in any sideways direction, just before my pipes turn 90 deg into a roof space.
I am aware of the loop system with 2 flexible couplings will give me a lot of movement, but they take up a lot of vertical room and I only have about 1.5 meters in the pipe before the bend. My problem being the pipe is large and under 8 bar pressure.
Any advice appreciated.
Re: fFexible joint for a 200mm dia pipe
03/25/2008 6:52 AM
Re: Fexible Joint for a 200mm Dia Pipe
03/25/2008 8:59 AM
See the pipe and joint at http://www.acipco.com/international/pipeandfittings/restrained/flex-ring.cfm (that would appear to supply the capabilities you seek)
