Previous in Forum: How to Select Software Developer?   Next in Forum: Simatic S5
matlab source code for mosfet inverter and adder
03/25/2008 8:22 PM
i'm looking for matlab 7 programmming source code for mosfer inverter and adder. i'm having problems in calling the function for the matlab function block for simulink.
Re: matlab source code for mosfet inverter and adder
03/25/2008 9:05 PM
what problem?
03/25/2008 9:46 PM
how to call a matlab programming function/function file from the MATLAB function block? in other words, how to insert matlab programming function in the MATLAB function block?
03/25/2008 10:19 PM
how to?
at first assign the subsystem and the function block then
use add_block command,
then set_param...
you;d better put forward your simulink disgram hre. so that I can make more clear your meaning.
03/04/2010 3:31 PM
I need to design a project based on a mos transistor in matlab showing the outputs of Id, Vd and also show the implementation of the 'body factor'. How do I do it ? Please help here !! Much appreciated sir, thanks. Farhan
Register to Reply 4 comments
Anonymous Poster (1); cnpower (2); redgurl (1)
You might be interested in: Bar Code Scanners, Bar Code Cards, Bar Code Software
