We are fabricating a 10' wheel for a museum display, which will hold a custom acrylic hourglass case. The wheel will rotate 180 degrees every 15 mins. During "mock-up", We have the case filled with 150lbs. of sand, draining through 2 1/2" holes. The volume of sand is about right visually,& the flow time works out for the fifteen min. My question is, that right now with the "mock-up", the top of the hourglass is open. When we fill the finished case it will be sealed around the perimeter with silicone. By making the case air tight, is that gunna change the flow rate of the sand as far as air displacement. The current mock-up is just the upper half of the hourglass shape, with the top being totally open, & we are just draining the sand back into 5 gal. buckets. Thanks Appreciate any input.
