We have a hydraulic driven diaphragm compressor over here used to compress hydrogen from 18 bar to 26 bar.
Recently we overhauled one of the 3 compressors and replaced its crankshaft and the diaphragm, but when we tried to take it in line, it starts with lots of knocking and the pressure starts rising abruptly.
We checked the oil circuit and ensured no air lock by priming it through an inbuilt hand pump manually.
But to control the abrupt pressure rise, we need to adjust the PRV in the oil circuit which releases the excess oil under the diaphragm and helps to maintain uniform pressure.
Now the problem is that the PRV can only be set using gas (N2) on the test bench as we have no facility to set it using oil.
We also tried to set the PRV online but the abrupt pressures disturbs the system and even the main header pressure gets out of control.
Now my questions are:
1> Is it OK to set the PRV by N2 in place of its actual working media i.e. oil. Will the set values not vary when we put this PRV in line.
2>Can we run the compressor with suction open and discharge close.. with vent crack open? (So that the PRV can be set online without disturbing the system)
3> What can be the probable reasons for the knocking?
