Previous in Forum: how to calcualte noise level   Next in Forum: air conditoning system
Two stage cascade refrigeration system
04/02/2008 9:22 AM
1. What should be done to optimize a two stage cascade refrigeration system?
  • Which components should in particular be considered?
  • What are the important parameters to be considered?
Re: Two stage cascade refrigeration system
04/03/2008 5:10 AM
Not being a "fridgie" all I can say is if the cascade system was designed correctly it is important that all components in both the circuits are working correctly and efficiently otherwise problems will occur.
Is there a problem with the unit, what temperatures are you dealing with, e.g. -700C, are your condensers water or air cooled, are your condensers fouled, what refrigerant are you using, have you checked your suction and discharge pressures on both units........................more information please.
