Previous in Forum: helpme experts for designing a scrubber   Next in Forum: selective reflection
12 comments
Piping materials for Dilute CLO2
04/02/2008 4:18 PM
I'm currently looking at a job to replace 1200 feet of 1.5" CPVC piping with something more rugged, and we've pretty much settled on Kynar-lined Sch40 carbon steel. I know there are some other alloys of stainless that might work, 654 SMO is one that has been suggested. We also considered titanium, but welding practices appear to make it more expensive than Kynar. Our concentration is 2 grams/liter, temperature is ambient (40F to 70F depending on the weather). Anyone tried anything besides the Kynar or titanium with any success?
Thanks,
Scott
Good Answers: 53
Re: Piping materials for Dilute CLO2
04/02/2008 7:48 PM
Aluminum is compatable with Chlorine Dioxide.
04/03/2008 2:14 AM
Yes Ace Boeringa, you are right, but the corrosion rate of Chlorine Dioxide with Aluminium (at 10 oC & 100% concentration) reaches 508 micron/year.
Also, I think the Titanium is compatible with Chlorine Dioxide since its corrosion rate (at 93 oC & 20% concentration) reaches 50 micron/year.
Note. The prescribed data was extracted from NACE code, Corrosion Data Survey, Metals Section-Sixth Edition (Pages 34 & 35).
Good Answers: 53
04/03/2008 2:24 AM
Abdel is also correct. Price and availability of aluminum is more attractive than that of titanium. Also the stated concentration is 0.2%
04/03/2008 2:32 AM
Yes Ace Boeringa,
I agree you.
04/03/2008 3:17 AM
does fiberglass pipe works?
would fibreglass replace myself?
04/03/2008 4:01 AM
Sure, fiberglass pipes can work correctly with chlorine dioxide, but till now I have no reference.
You have to make a lap check for fiberglass to withstand the corrosion of chlorine dioxide and check for any changes after 7 and 21 days. Otherwise, wait for additional assistance from CR4 members.
04/04/2008 1:06 PM
There are potential issues with delamination along this length, in accordance to whatever layup you use.
All this worldly wisdom was once the unamiable heresy of some wise man. -Thoreau
04/03/2008 4:11 AM
This are the only materials for which the Corrosion Rate is below 2 mpy (0.05 mm/y). The data are taken from Corsur of NACE (knovel).
Alloy
Conc
Temp (F)
CR (mpy)
Titanium, Unalloyed5 – 25175 – 225<2
Tantalum10025 – 175<2
Silicon Cast Iron (14Si)10052 – 147<2
There are many others materials with Corrosion Rate below 20 mpy (0.5 mm/y).
hope this help
S
Corrosion Control & Corrosion Protection
04/03/2008 5:49 AM
mpy = Mils per year
1 Mils = 0.001 inch = 25.4 micron = (25.4/1000) mm
Hobbies - DIY Welding - pipewelder
04/03/2008 10:17 AM
If CPVC will work then why not run it or Kynar in a larger pipe made of stainless or carbon steel to support and/or protect it? I have done this many times on acid lines and it works very well. you do leave the ells exposed but with some planning on the routing the danger of them being damaged is small. Also you could use titanium for the exposed ells and the CPVC run inside a sheath of steel pipe on the longer straight runs. This could make more chances of a leak because of the flanges/gaskets though but it would be allot cheaper to do this way. I am not sure what your layout is but when I do this I try to run it in an area that is out of harms way from being damaged or having contact with people. I am sure that the main thing is safety with this system and you may not want to take any chances of having a leak. In this case the titanium pipe would be the best I think because all of the flanges associated with the Kynar lined pipe.
pipewelder
pipewelder
04/04/2008 1:27 PM
Thanks to all for responses and suggestions. After some debate, and considering costs, risks, 'comfort factor' with the materials and experience with assembly, we've chosen to stick with Kynar-lined carbon steel. We only have one welder that can weld Titanium with any skill, and the local crews have built a bunch of Kynar-lined pipe the last couple years. Some other options we looked into were 254-SMO, but the material costs were way out of line ($80/foot for 1.5"!). I'll follow up when we're done with final costs per foot of installed pipe, in case this comes up for anyone else in the near future.
Scott
04/09/2008 4:03 PM
CPVC lined (bonded) FRP armored (makes very rugged) is an excellent solution.
FRP by itself will do the job (using a premium vinyl ester corrosion resin).
Let me know if you need a quotation. I am Canada.
Register to Reply 12 comments
Abdel Halim Galala (4); Ace Boeringa (2); Ben Bonsens (1); pipewelder (1); strider6 (1); thinman56 (1); Turk (1); unicomposite (1)
