Previous in Forum: ImplosionWorld.com   Next in Forum: Part 1: A Giant Nationwide Engineering Project
Friend of CR4
The Truth About Evaporative Coolers
06/23/2006 1:25 PM
Want to increase productivity at your plant? Maintain a comfortable interior climate. When workers at a warehouse in Memphis, TN complained of the heat, engineers solved the problem using an Evaporative Cooler system. The system was viewed by facility personnel as a sure way to inflict damage upon the manufactured materials. After all, Evaporative Coolers are a "wet" system and thought to be effective only in hot, dry climates. But after installing a series of rooftop "swamp coolers," the plant's temperature was reduced and products remained undamaged. The lesson? Evaporative Cooling systems can be used in all regions, and they are an efficient and economical means of cooling an industrial facility.
The preceding article is a "sneak peek" from HVAC, a new newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to HVAC today.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Swamp Coolers
06/26/2006 3:29 PM
What exactly is a swamp cooler?
75 Megahertz is fast. Right?
Re:Swamp Coolers
06/27/2006 8:46 AM
A Swamp Cooler is an air handling unit with a wet medium and a 100% outside air fan. The medium is wet continuously with fresh water and as the air passes over it evaporates water and lowers the sensible heat (dry bulb temp.), but increases the humidity. As opposed to an air conditioner which has a coil with chilled water or refrigerant that cools and dehumidifies the air as the fan blows it over the coil.
Swamp coolers are simple and relatively inexpensive, but are NOT very effective in humid climates, as very little water evaporates. You often see simple versions of this at football games and such with big fans on the sidelines with a water mist.
If you have an instance of an air conditioned space next to a swamp-cooled space, part of the swamp cooler supply can be derived from the AC condensate drain. Using this water which is usually sewered or drained to the ground will replace some of the water demand and is colder than most water supplies.
Register to Reply 2 comments
You might be interested in: Water Coolers, Evaporative Coolers, HVAC Services
