Previous in Forum: worm gearing   Next in Forum: torque calculation to move (to control) a butterfly valve
URGENT
04/04/2008 11:30 AM
HELP!!! PLease, i need assistance urgently. I need to design a 5kg LPG cylinder. I need design processes and calculations.
This discussion was "closed" on 04/04/2008 12:04 PM. No new comments are allowed.
Message from admins:
Design of such devices are regulated by local and federal laws.
Good Answers: 66
Re: URGENT
04/04/2008 11:58 AM
Are you in the U.S.? If you are, design of portable LPG cylinders is governed by DOT-4BA240. Your cylinder will require a UL certification - they can probably guide you in the specific tests that will be performed during the certification process.
BTW - do you need exactly 5kg capacity? There is an existing 12lb. standard cylinder design that is commonly available.
Aequam memento rebus in arduis servare mentem.
