Hello All,
I'm dealing with a failure analysis of a blind flange installed on a new 6" HDPE tee in a pressurized water line. We had a situation where a blind flange experienced a significant leak (regulators are mad at us). This assembly was under ~60 psi of pressure, and had been successfully hydrostatically tested (2x service pressure for 2 hours) only ~10 days previously.
This assembly was installed in a subsurface vault, and after disassembling the leaky flange we noticed that the gasket (neoprene) had a slight bulge on one side. It was not torn, cut or damaged in any other way. Is this a sign of the flange being tightened incorrectly (100 ft-lb torque)? This bulged gasket is the only evidence we have of anything out of the ordinary. The flange was installed in ~67 degree-F, temperature during leak was ~38-degree-F. Temperature issues?
thanks!
