PLANT: Saurashtra Cement Date: 3/15/2008
Altitude 47 m Density 1.003 kg/m3
Barometer 10275 mmWg Area 4.522 m2
Type of pitot tube Avg speed 8.78 m/s
Ps Static Press. -1 mmWg FLOW 142987 m3/hr
Temperature 76 oC 2383 m3/min
Normal dens. 1.29 kg/Nm3 39.72 m3/sec
Duct diameter 2.4 meter 111181 Nm3/hr
30.88 Nm3/sec
Pd, mmWg v, m/s 143.42 Ton/hr
4 7.48
5 8.36
6 9.16
7 9.89
5 8.36
7 9.89
6 9.16
5 8.36
6 9.16
5 8.36
6 9.16
5 8.36
5 8.36
6 9.16
5 8.36
5 8.36
6 9.16
7 9.89
5 8.36
5 8.36
i am a new member and i have a typical doubt may be silly but still i wanna confirm.
As u see above from the table sheet provided above i want to calculate the density of gases in Kg/m3 , i am using the formula kg/m3 = normal density(kg/nm3) *273/(273+temp measured)*10275(Alt47m)-(-Ps)/10336. I am having a doubt in static pressure whether it is (10275- Ps )or is it (10275-(-ps)). Some one told me that one should take -ve value at suction side and +ve value at discharge side. I want u to correct me whether which formula is right so as to clear my doubt.
