Previous in Forum: Halogen lamps blowing rapidly?   Next in Forum: what is the application of NGR in fault level calculation of transformer and gee
8 comments
Fault Level Calculation of Electrical System
04/06/2008 6:57 AM
dear all
any body tell me about fault calculation of electrical systaem by MVA method.how can we select the base MVA of system and what is other considerable parameter in fault level calculation.
regards
suresh kumar paliwal
Good Answers: 42
Re: fault level calculation of electrical system
04/06/2008 3:06 PM
The calculation of greatest fault current of system is required for calculation of the capacity of the switchgear or bus bar or cable. The source of the supply will be the consideration.The MVA/kVA capacity of the transformer or generator which is the source. The simple equation to find the short circuit current is
1.1 x V L
I = --------------- Amps
√ 3 x Z
I - short circuit current
Line voltage is multiplied by 1.1 to take care of 10% rise in voltage
Z Impedance in ohms
% Z x10 x kV 2
Z = ---------------------
kVA
Detailed calculation method is available in www. ecmweb.com
You must read it if you are really interested to learn the subject.
There are so much reading material on the subject in the net itself
Similarly read this link
http://books.google.co.in/books?id=yiT9Doq8TRwC&pg=PA184&lpg=PA184&dq=short+circuit+calculation+of+bus+bar+&source=web&ots=L1ww-bULxl&sig=Ker1LfRB8E9pWC5-fKnyNqPi_K0&hl=en#PPA184,M1
Reply: fault level calculation of electrical system
05/05/2009 2:50 AM
Hi
To evaluate the fault level of a system follow the steps noted below
Base kVA as 1000 kVA or 1MVA
% System imepdance at 250mVA as 100% ( I have considered 11kV system and assumed 250mVA (Max)
Convert %System Impedance at 1MVA = 100/250 = 0.4%
%tx Impednace = 4%
% total impednace = 4.4%
Fault level @ 415V side = 100/4.4*1 = 22.7MVA
Fault Current @ 415V = 22.7*106/ 1.732*415 = 31KA
Max fault current 31*1.1 = 35KA (due to Variation in system voltage)
Krishnan Subramoniam
AECOM
Sydney - Australia
06/02/2009 10:47 AM
What will be the fault level of the supply with
1. 415V, 144KVA? transformer impedence= 0.08, Vsec=100V, VA= 4000
2. 11kV, 25MVA? trans imped= 0.069, Vsec=800V, VA= 3.2MVA
Thanks a lot
06/02/2009 12:34 PM
06/03/2009 8:32 AM
Thank you very much..
12/25/2009 7:08 AM
Hi...sir......
how are you?
i am amit kansagara from Essar Powwer-Jamnagar,
are you know me?
01/25/2010 7:16 AM
max. impedense value for any rating for the transformer is cosidered as 5% of the rating. therefore for example:-
for 1000KVA, THE FAULT LEVEL CURRENT WILL BE
1000x5%=1000*.05=50KA
ASIF HUSSAIN
05/13/2010 8:54 AM
Wrong....absolutely wrong
Alanvaderi (1); Anonymous Poster (3); powerelec (2); V.I.Abraham (1); wareagle (1)
