Previous in Forum: Theory of failure in Piping Stress Analysis   Next in Forum: lead ballast
NASM standart high strength shoulder bolt
04/09/2008 8:52 AM
Hello,
I am searching a NASM standart shoulder bolt (NAS1297 or NAS1160 have not enough tensile strength unfortunately) which has a UTS (ultimate tensile strength) of at least 220 ksi (around 1500 MPA) to be used on Aircraft Secondary Structure.
Re: NASM standart high strength shoulder bolt
04/09/2008 12:09 PM
Well, the size of the bolt will make a small difference, use an standard grade 8 bolt, but to achive the 1500 MPA you'll either need more bots or larger bolts.
Good luck,
