I have a burned out transformer serving a swimming pool UV sanitizer and am trying to determine if the (boost) transformer was sized right.The line voltage is 208y 3 phase and the UV swimming pool sanitizer is rated at 480 volt 3 phase and is drawing about 6.1 amps per phase. What size transformer do I need to replace our burned out unit? The burned out unit in place now was rated at 6KVA, 208 volt sec. and 480 volt pri. wired as 208 volt pri. and 480 secondary voltage.I understand that is OK to reverse wire these units. But this unit ran very hot from the get go.Can you tell me the correct size boost transformer I need to purchase? We have been without an electrician for some time so I have no advise on sizing transformers at this time.
jcall@sgc.edu
