Previous in Forum: ASME   Next in Forum: Problem in Bearing Assembly
12 comments
hydrotest
04/12/2008 6:33 AM
Dear Gents,
I am facing problem during hydro test,during the test pressure is rising high or some time low due the temperature difference.so i would like to know the formula to calculate the pressure difference dueto temperature.or give any reference from CODE.That will be helpful.
Thanks.
Good Answers: 143
Re: hydrotest
04/12/2008 7:34 AM
As I understand your post, you're doing hydrostatic testing and seeing a large pressure difference due to temperature. Is this correct? Can you provide some specific details of that?
Re: hydrotest
04/12/2008 10:51 AM
whats the pressure you are testing
also mention the temp. difference and the volume of tank.
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
Re: hydro test
04/13/2008 2:16 AM
Your tests should be completed at a temperature of 65*f plus or minus 5*f. Testing with hotter water will give a false leak tests because cold water can leak under conditions that hot water may not. The Navy and bureau of shipping will not allow hot hyrdotests. Don't try to out smart your vessel hyrdotest at 65*f.
Mike
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
Re: hydro test
04/14/2008 7:34 AM
How is it that cold water will leak where warmer water does not?
All generalizations are false, including this one.
Re: hydro test
04/14/2008 8:22 AM
I agree. There must be something wrong in the system, not in the temperature of the medium. Remember that the physical property of water is almost constant in its liquid state, and its virtually incompressible property is the reason why it is used for hydrotesting.
All these other excuses/theories/explanation are pure B.S.
"It is only when we die that we become Immortal."
Re: hydro test
04/15/2008 12:07 AM
In this case the word ALMOST takes on a new meaning. Water does not compress but it does expand...
Good Answers: 143
Re: hydro test
04/14/2008 8:36 AM
CTE
Re: hydro test
04/14/2008 10:26 AM
I would venture to guess that the ideal operating temperature of the water line is expected to not leak under normal operating conditions.
Temperatures above normal operating temperatures would cause fittings and other associated materials to expand and seal up any potential leaks during testing.
Temperatures below normal operating temperatures would cause fittings and other associated materials to contract and cause leaking when a leak wouldn't ordinarily be present.
Then there is the issue of testing under conditions that are warmer then normal operating conditions and after cooling and the seals not resuming shape after being compressed by the expanded fittings causing leaks until the seals resume their normal shape.
Re: hydro test
04/14/2008 11:58 PM
Its a fact. If you fill a large vessel up with 60*f water and "squeeze it" you made find "weeper". If you do the test with 70-75* f water the weepers will be less noticable. Done it dozens of times 30% you will see moisture. There must be something to this because the authorities will not allow hot water hyrdo test.Obviously if you are in an area that is very hot and ground water is also hot you have no choice. I have never been in that position though.
Re: hydrotest
04/13/2008 8:39 AM
Include me in the thread.
I would like to see the comments from all of our astute members.
Re: hydro-test
04/13/2008 10:06 AM
The variation will be governed by pv/t.As your volume is constant v.Maintain P/T do not worry of 65f, many places ambient is 105f.
Re: hydrotest
04/13/2008 11:23 AM
I recommend using of a recorder for pressure along 24 hours only if there is no a limitation by the process or there is no limitation for the long period to corrosion to occur, and taking into account to avoid freezing of the hydrostatic fluid inside the piping system. In addition a close observation is required to any higher variation of pressure during recording. You can install a relief valve into your piping system to avoid any excessive raising of pressure. At end of 24 hour, you can analyze the variations, and if you found that the reading of pressure at the same time of day are equals, here be sure that your system is approved.
Abdel Halim Galala (1); Anonymous Poster (1); High Lander (1); Janissaries (1); miketheboilerguy (3); qaqcpipeman (1); ratnagiri (1); TVP45 (2); Worksalot (1)
