Previous in Forum: Turbine Blade manufacturing process and planning   Next in Forum: Regarding flexible bellows
Looking for pliable FDA seal/gasket for valve seat
04/13/2008 5:12 PM
Wish to find source for comercially available seals/gaskets, probably silicone, to use as a seal in a mechanical , non-rotating valving function (up to open, down to seal). Application is for potable hot water (200 deg.F max.).
Thanks,
Rockmon (North Eastern USA)
Pathfinder Tags: gaskets seals silicone valve seal
Re: Looking for pliable FDA seal/gasket for valve seat
09/04/2014 2:35 PM
Hi,
Unsure if you found your source for your potable hot water but we manufacture FDA certified rubber gaskets & seals.
Please contact us at 732-777-0288 for more information and we will try to fix your issue.
