One of our client spec calls for the PSVs inlet flange min rating shall be 300#. In many cases the vessel is designed for 150# rating. all the nozzles are 150 # flanged. my questions are :
1. Why the client spec calls the min rating for PSVs inlet flange shall be 300 # rating? is there any technical reason behind this?
2. Can I use 150# rated pipes till the inlet of PSV and use a counter flange of 300# is welded to this pipe to mount the PSV on it?
