Previous in Forum: Part for an Outdated Loading Arm   Next in Forum: Does water get freezed under vacuum?
seam less
04/15/2008 1:55 PM
what is the difference between seamless pipe & welded pipes
Good Answers: 61
Re: seam less
04/15/2008 5:11 PM
Pipe is made using two specific methods of manufacture. It is made by taking a flat plate, called a skelp, and rolling it into a tube shape and then welding the two edges together to form a tube. This pipe is commonly called "welded pipe" or ERW pipe. The other way is to take a solid bar or billet and pierce a hole through the length. This pipe is commonly called seamless pipe.
Do it once and do it right
Reply to Forum Thread
