I was considering adding a second, gas-fired water heater in parallel, at the end of the too-long line, in order to boost pressure and flow to the last consumer (a shower nozzle) on the line. Certain buddies warn that the two tanks must be exactly matched (i.e., balanced) in size and pipe connections...or one might dominate/shut-out the other. I would contend, on the the other hand, that, so long as tank heights (or stored water surface elevations) are equal--and all other things being equal--that multiple tanks will self-balance, irrespective of relative tank size. Neither tank will be "locked out." Who's correct? and why?
PS: Please disregard that the second tank's input would be connected to the outdoor supply line in a closed loop configuration of both tanks. Just think: two tanks in parallel; Will both flow (at all) on demand? Or won't they?
Thank you.
