Previous in Forum: compressor efficiency   Next in Forum: Different class and grades of surface finish? Is it different?
roughness factor for mild steel
04/24/2008 2:58 AM
i calculate and designed a fume extracting system on your help. i used galvanized steel sheet (G18) for calculating the friction loss. i need to know the methods to fabricate duct systems using galvanized sheet.(is Gas welding good?) otherwise mild steel sheet is good because it easy to weld. so please tell the roughness factor for mild steel compare with galvanized steel sheet to multiply the pressure loss i calculated using galvanized sheet.
Re: roughness factor for mild steel
04/25/2008 1:01 AM
So let me be first to ask. What kind of fumes from what kind of production equipment?
One doesn't usually weld sheet metal for such systems; merely bend and crimp.
But more information would be a help to intelligently answer your questions.
j.
04/25/2008 4:53 AM
Production equipment is a rim (tyre production ) and the material is mild steel. we using MAG Plant for welding.
04/25/2008 9:16 AM
Welding galvanized steel is not a good idea, due to the zinc fumes released. Use a mechanical means, like folding and crimping, or adhesive instead.
Register to Reply 3 comments
HarryBurt (1); Jack Jersawitz (1); schathuranga (1)
