Previous in Forum: Heat utilization in the emulsion separation process   Next in Forum: Diffusion Coefficient
electrolysis of aqueous sodium bicarbonate
04/27/2008 7:02 PM
Has anyone actually analysed the results of the electrolysis of aqueous sodium bicarbonate solution?
What happens when the bicarbonate anion loses an electron? Are you guessing?
What happens when an aqueous solution of sodium carbonate undergoes electrolysis?
Will eventually you get a solution that you cannot tell the difference between the two (and still have water left)?
Pathfinder Tags: electrolysis
Re: electrolysis of aqueous sodium bicarbonate
04/28/2008 8:58 AM
The loss of electrons is oxidation and this principle would apply to bicarbonate. No I am not guessing.
Think of the carbonate, bicarbonate, CO2, and carbonic acid in an aqueous solution existing together in dynamic equalibrium. As you manipulate the pH of this solution, the dynamic equalibrium will be forced to adjust to these changes. Carbonate being most basic, bicarbonate less basic, aqueous CO2 as a weak acid, and carbonic acid as the pH trends lower.
You did not state what the electrodes were made of. Check out Faraday's laws and Professor Google.
01/13/2009 1:55 PM
What are the answers to these questions?? Where can I find these answers??
04/04/2009 8:00 PM
baking soda will not make hydrogen... it makes co2
Register to Reply 3 comments
ben 78 (1); mbrew1 (1); user-deleted-9 (1)
