Previous in Forum: Pool heater calculation program   Next in Forum: Leaking Stainless Steel Hot Water Tank
10 comments
Proxmity Sensor
04/28/2008 4:42 PM
I want to put a proxmity sensor on the bottom of my air dam on the front of my car. I want this sensor to trip a light bulb or some device when it gets within a certain distance to the pavement (i.e. 5 mm). I'm actaully looking for something that will tell me when I scrap the pavement but wasn't sure if this existed. Are there any ideas?
Thank you.
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
Re: Proxmity Sensor
04/28/2008 6:54 PM
In the 40's and 50's a device called a curb feeler was used to attach to the fender at about rocker panel height. This devise usually consisted of a piece of spring wire (like what some radio antennas are made from) with a ball on the end which, when coming in contact with the curb, would reverberate through the car's sheet metal.
I'm not sure how well this would work on todays vehicles due to thier better sound dampening. Also if you have a big sound system that you keep cranked up you might not be able to hear it.
You might still be able to get these through J.C. Witney. com.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
Re: Proximity Sensor
04/28/2008 7:34 PM
How about a limit switch with a whisker actuator. You could probably get one on e-bay for next to nothing...
Life is what you make it...
Re: Proxmity Sensor
04/28/2008 11:52 PM
Here is a place to start http://en.wikipedia.org/wiki/Proximity_fuse
Now look into toy robots guidance systems and go from there.
It's not my forte' but the systems are similar.
Brad
Re: Proxmity Sensor
04/29/2008 3:31 AM
Google - car reverse warning sensor - you should find what you need. They detect distance by radar signal.
Many cars (Europian) have these sensors built-in - except their mount is such as to detect collision when reversing into parking space. I think they could be easily re-mounted to detect what you are looking for.
I would call a scrap yard it you like to do it cheaply.
Good Answers: 97
Re: Proxmity Sensor
04/29/2008 4:22 AM
The Wii mouse is an actual proximity sensor
Good Answers: 94
Re: Proxmity Sensor
04/29/2008 6:16 AM
Parking sensors seem obvious but would they detect a low object like a kerb?
If anyone has a car with sensors built in perhaps they could try it.
Good Answers: 97
Re: Proxmity Sensor
04/29/2008 9:59 AM
If a motion sensor for a lighting application could be activated below a set speed...
04/29/2008 10:13 AM
Depending on how much you want to spend you might look at an Ultrasonic sensor. I have used many for proximity detection in the industrial environment to detect components. The units usually are expensive, but I checked E-bay and found a turck sensor for $25.00. http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=ultrasonic+sensor&category0=
I would stay clear of the car alarm units they have too wide a pattern. The backup sensors are probably set for too far a distance but might be adjustable. But the industrial sensors would do just what you wanted. I would also stay clear of Photoelectric proximity sensors. These would get dirty too fast.
Good luck.
Good Answers: 97
04/29/2008 10:15 AM
Good points all...
Re: Proxmity Sensor
04/29/2008 1:29 PM
http://www.lynxmotion.com/
They have infrared sensors good in daylight for up to 26 inches and ultrasonic sensors good for up to three meters.
BCT (2); bwire (3); Jonny5 (1); Nigh (1); Shadetree (1); silvCrow (1); U V (1)
