Previous in Forum: DC MOTOR   Next in Forum: How Does a Zig-Zag Transformer Sense the Earth Fault?
9 comments
A 4th Basic Circuit Element: The Memristor
05/01/2008 1:10 PM
In what could be the most significant invention since the transistor,scientists at HP labs have created a new circuit element, the memristor or a resistor with memory.
It won't be long until we have computers that boot up instantaneously.
http://www.nature.com/news/2008/080430/full/news.2008.789.html
What other applications can you suggest for this new device?
Charlie don't surf.
Good Answers: 52
Re: The 4th Circuit Element: The Memristor
05/01/2008 1:17 PM
Looks cool
Re: A 4th Basic Circuit Element: The Memristor
05/01/2008 10:59 PM
I read the EE Times article and wondered to myself, why is the 'fourth' circuit element a non-linear device and the other three basic circuit elements (resistors, capacitors, and inductors) are linear devices?
Good Answers: 213
05/02/2008 9:29 PM
It seems to me that resistors, capacitors and inductors are only linear in their IDEAL states...Or maybe I am doing something wrong? Capacitors do not accept charge at a constant rate over time, inductors have a quick short-circuit spike when activated, followed by rather non-linear response when the core is saturated, and have you ever overloaded a resistor? Can that explosion be considered a linear response?
Good Answers: 54
05/02/2008 12:02 AM
It looks like a potentially useful device, but I don't understand why it would be considered a new "basic" circuit element. You'd still model it using the 3 real basic elements and some terms to cover its history. Remember the tunnel diode.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
05/02/2008 12:09 AM
"In what could be the most significant invention since the transistor,scientists at HP labs have created a new circuit element, the memristor or a resistor with memory."
Could this have any relation to Tom Bearden's negative resistor?
05/02/2008 11:03 AM
Diodes are not considered a basic circuit element?
The Engineer
Good Answers: 129
05/02/2008 11:31 AM
Hi all. I too was confused about what made a memristor on the same level as a resistor, inductor, and capacitor (basic circuit elements). I found the following explanation on wikipedia:
The four fundamental circuit variables are current, I; voltage, V, charge, Q; and magnetic flux, Φm. Only 5 elements are required to represent any component or network by manipulating these four variables:
  • Two sources:
    • Current source, measured in amperes - produces a current in a conductor. Affects charge according to the relation dQ = − Idt.
    • Voltage source, measured in volts - produces a potential difference between two points. Affects magnetic flux according to the relation dΦm = Vdt.
  • Three passive elements:
    • Resistance R, measured in ohms - produces a voltage proportional to the current flowing through it. Relates voltage and current according to the relation dV = RdI.
    • Capacitance C, measured in farads - produces a current proportional to the rate of change of voltage across it. Relates charge and voltage according to the relation dQ = CdV.
    • Inductance L, measured in henries - produces a voltage proportional to the rate of change of current through it. Relates flux and current according to the relation dΦm = LdI.
A fourth component, the memristor, has been proposed but is not generally accepted as one of the basic circuit elements. It was reported on April 30, 2008, that a working memristor has been developed by HP. It would have a memristance M, and would relate magnetic flux and charge by dΦm = MdQ, so that every pair of variables would be related.
So if I'm reading this correctly, its considered a basic circuit element by some because it relates charge and magnetic flux, two of the fundamental circuit variables.
Given (V,I,Q,Φ), the possible combinations are:
V,I - Resistor
V,Q - Capacitor
V,Φ - Memristor
I,Q - Current Source
I,Φ - Inductor
Q,Φ - Voltage Source
Anyway, that's how I'm understanding it.
Unlike other circuit elements, Memristance is a function of charge
07/22/2009 11:37 AM
V,I - Resistor
V,Q - Capacitor
V,Φ - Memristor
I,Φ - Inductor
I love the idea of memristance fitting into the relationships between voltage, charge, inductance, and flux, BUT I have a question about this:
  • Q,V - Q=CV
  • V, I --> V=RI
  • I, Φ --> Φ=LI
  • Φ, Q --> Φ=MQ
That's great. Let me analyze Φ=MQ. dΦ=M dQ. dΦ=v dt, so v dt = M dq. This means dq/dt =V/M. dq/dt = I, I=V/M. That's ohms law. The only difference between M and R is that M is a function of charge.
That's fine, but in all the other relationships, C, R, and L are constants. M, however, is a function of q. Does anyone know what the function is? Since M is a function, not a constant, isn't the relationship between flux and charge fundamentally different from the other relations.
Charles J Gervasi
09/12/2009 6:03 PM
I believe the relations are
V= dΦ/dt, voltage source
I = dq/dt, current source
V = k*I, resistor
V = k*q, capacitor
Φ = k*I, inductor
Φ = k*q, memristor
[I would say that V,q is a memristor and V,Φ is a voltage source]
Register to Reply 9 comments
Anonymous Poster (2); Bayes (1); Brave Sir Robin (1); cgervasi (1); cwarner7_11 (1); ffej (1); frankd20 (1); Stirling Stan (1)
