Previous in Forum: PID Controllers   Next in Forum: Orfice Equation
flow transmitter
05/11/2008 10:08 AM
i am facing an problem
turbine steam inlet flow meter with orifice plate and ACC condensate return flow meter is Vortex flow meter
( "actually the inlet steam is less than the outlet condensated water " )
turbine inlet flometer
range was 0-2000 mmH2o
it is converted into 47 TN/hr but
actually the range was suppressed into -38.9 mmH2o to 4284 mmH2o
what is the calculation to convert mmH20 to TN/Hr how the problem can be solved
Good Answers: 53
Re: flow transmitter
05/11/2008 12:28 PM
There are several variables, here is a link that should be helpful.
http://www.clabberhead.com/sob.php
05/12/2008 11:12 AM
Your question is not very clear,so I am going to assume what you meant.
You have an orifice plate sized to have a differential pressure of 2000.00 mm H2o when 47 tonnes/hr of steam is flowing through it,but somebody calibrated the flow transmitter to -38.9 to 4284 mm H2O.How to intrepret the actual flow with the wrong calibration.
The signal output from a transmitter is directly proportional to the differential pressure across it.
The differential pressure across the transmitter however is proportional to the square of flow.
Suppose you read a 30% signal(I am assuming no square root extraction is done in transmitter) then this represents (4284+38.9)* 0.3= 1296.87 mmH2O.
2000 mmH2O=47 tonnes/hr.Therefore 1296.87 mmH2O is equal to square root of
1296.87/2000 * 47=37.846967 tonnes/hr.
If you don't know where you are going,you are bound to get there
Register to Reply 2 comments
