Previous in Forum: Analyzer for cyanide   Next in Forum: Condensation Problem in Electric Room
Electrode Qualification Requirement
05/14/2008 10:03 AM
Dear all members,
I have a query regarding electrode E6010 & E8010-G batch qualification test requirement as per ASME Sec II-C.
We have procured E6010 (SFA 5.1) & E8010-G electrodes and now we want to do their batch qualification test. Which type of tests (chemical, mechanical, RT etc.) are required for their batch qualification as per ASME Sec II-C ?
Which are other things that I have to check in their T.C. (Manufacturer's Test Certificate) apart from these qualification testing ?
I will be very grateful if anybody can give me reply in little details regarding exact type of testing.
Thanks & Regards,
PR
Re: Electrode Qualification Requirement
05/14/2008 11:21 PM
Please refer to ASME code, Section II, Part C:
♣ For electrode E6010: Chapter SFA-5.1 "SPECIFICATION FOR CARBON STEEL ELECTRODES FOR SHIELDED METAL ARC WELDING", Table 4-Required Tests.
♣ For electrode E8010-G: Chapter SFA-5.5 "SPECIFICATION FOR LOW-ALLOY STEEL ELECTRODES FOR SHIELDED METAL ARC WELDING", Table 5-Required Tests.
Note. If you don't have these tables, please let me know your e-mail and I will send you a copy.
05/15/2008 10:12 AM
Dear Mr. Abdel Halim Galala,
Thanks for your reply.
I want to further elaborate on this.
As you also mentioned, for E6010, SFA-5.1, Table 4 represents required tests.
We have size of electrode is 3.2 mm, so for this size "no testing is required", as I interpreted. Am I correct on this ?
And what about manufacturer, even he is also not required to do any testing if he goes by this specification (SFA 5.01-schedule I or J)....then on what basis he can certify E6010 electrode having 3.2 mm size ?
So, as far as SFA-5.1 is concern, for E6010 electrode with 3.2 mm size no testing is required ??
I am confused on this point. Can you please explain or clarify my doubt ?
ALso, I am not able to interpret the note (2) given at the bottom of Table-4.....what actually this note (2) means ?
I will be grateful to you and will appreciate your reply on this for my better understanding of code.
With Best Regards,
PR
05/15/2008 10:15 AM
With Best Regards,
PR
