Previous in Forum: HDPE I Beam load capicity   Next in Forum: cold worked components in piping
gear ratio
05/22/2008 10:27 AM
hello all
I want to open & close the lid of large cylinder with an electric motor
So the motor which I want to use are 16 & 17 RPM and the carrying load (mean weight of lid) are approximately 200kg .
the distence is appox 2500mm
moreover the gear of the motor will be drive the another gear. So I want to find out gear ratio that which type (Dia & no of teeth) of gear use for this application.
so plz help me
thanks
Re: gear ratio
05/22/2008 10:52 AM
How do you want it to open? Upwards like the bonnet of a car, Sideways like a sliding door turned on its side or sideways from a pivot point? Could you use a hydraulic ram?
Give us more!! What does it say on the motor? 1.5Vdc, 415Vac, 1Hp, 100Hp etc I assume it's a geared motor but who can tell, only you! Give us a photo if you can (preferably with the motors name plate in focus and easily readable)!
Re: gear ratio
05/22/2008 1:52 PM
hello mr Trumun Brain
actually the lid will be close and open horizontally by sliding motion due to limited space. i m installing the wheel on both side which is driving on railing like railway track. and the wheel will b couple by electric moter, so the power attain by moter,
so the moter is an reversibe electric gear motor with an rpm of 16 or 17
i want to find out the
1 gear ratio
2 gear diameter
3 no of teeth on gear
4 calculating formula
thanks
Re: gear ratio
05/22/2008 1:55 PM
OK, let's wait and see what comes up!
Good Answers: 15
Re: gear ratio
05/22/2008 2:54 PM
What is the desired speed? That will determine the Pitch diameter of the final gear.
What type of gear is currently on the motor shaft? Belt, chain, spur,?
How much physical room do you have?
Are the gears driving each other or are they connected by a belt or chain?
what is supporting the lid as it is being slid into the open position?
A sketch of what you want to do is in order.
There are too many unknowns to make a reasonable offer of help.
downhill slide to 112 (damn memor.)
Re: gear ratio
05/22/2008 8:59 PM
hi mr ddk
the speed should be that i want to close and open the lid with in 5--10 secound
the gear i want to spur
the area of actual room is 6.5m*5.5m there is limited space.in current situation the lid can b slide
there r gearimg drive
steel structure is supprt
ok thanks
Re: gear ratio
05/23/2008 12:15 PM
Have you considered a lead screw design?
http://www.exlar.com
http://www.lsitvc.com/
http://www.kerkmotion.com/
http://www.threadcraft.com
Many others out there on the web.
A linear movement is a good application for lead screws, ball screws, roller screw, etc.
Good luck with your quest.
Re: gear ratio
05/24/2008 1:11 AM
thanks for ur comments
sir i want to use the reversible electric motor with an rpm of 16 or 17
and the lid should b close and open with in 5--10sec
the movement of lid is horizontally and there are small wheel like on railway track
the distence is 2500mm and the weight of lid is 200kg
what gear ratio i choose for this purpose
i have seen the above web sites but there no result found
ok
thanks
Brave Sir Robin (1); ddk (1); Mr. Truman Brain (2); Sadiq Hussain (3)
