EFFECT OF PREHEATING ON MECHANCIAL PROPERTIES OF MATERIAL T91
05/26/2008 5:11 AM
HELLO GUYS
CAN ANY ONE TELL WHAT IS EFFECT OF PREHEATING WHILE WELDING BY TIG, ON MECHANICAL PROPERTIES OF SA 213 T91 GRADE STEELS SUCH AS TENSILE STRENGTH, TOUGHNESS, HARDNESS
Re: EFFECT OF PREHEATING ON MECHANCIAL PROPERTIES OF MATERIAL T91
05/27/2008 2:28 AM
Weld preheating in P91 steel, as in many others, is applied to reduce the cooling rate after welding (the temperature gradient is lower) and thus trying to minimize embrittlement of HAZ by martensite formation.
Preheating by itself, usually performed at relatively low temperature doesn't affect mechanical properties.
06/03/2008 7:23 PM
When you weld metals that have a high creep cracking problem, preheat is the best preventive.
When you weld on P91 and don't use a good preheat there is a very narrow heat affected zone, there are extreme stresses developed across this heat affected zone that are not completely removed with PWHT.
Preheat helps to make this heat affected zonal area wider and lets the stresses build or rather dissipate over a larger area. There are the same stresses but now there are not as concentrated in this very narrow band.
05/27/2008 10:05 AM
P91!
p91 Has been my bane in the past, so keep the comments coming. Preheat, inprocess heat, and postweld heat are all important here. And I have found cleanliness is of more importance than some other alloys.
05/27/2008 12:47 PM
Amen and more to all of those comments. Too bad that a lot of people take shortcuts. I remember seeing Pipefitters trying to weld at a dirty and dusty field site when the wind was blowing creating a wind chill of minus 0 Degrees F. A Most weld continued to fail as they were using a flame thrower for heat instead of using a blanket. Interesting, this Gas Turbine Powerplant never got commissioned.
06/03/2008 5:24 AM
PREHEATING: As its name says is not a POSTweld heat treating.
It's necessary as I've said in welding P91 material to lowering the cooling rate as in many weld-hardenable steels, but it's done at relatively low temperatures, so the preheating itself, even necessary, doesn't change the structure of P91 which had been tempered at more than 700ºC and therefore, doesn't change the mechanical properties.
Postweld heat treating of P91 is independent of the preheating or interpass temperatures or the convenience of a soaking time. It's a Code requirement technically based on the nature of the material.
