Previous in Forum: What Are the Burning Topics in Mechanical Eng?   Next in Forum: BP Learns From Pigs in a Pipeline
Flow Meter
08/11/2006 10:00 AM
Emmanuel writes:
Hello, all. We are looking for a flow meter capable of measuring/recording the flow rate of crude oil irrespective of the amount of vapour and water in it. At the same time, the flow meter must be easy to install on a pipeline up to 26-in. in diameter without the need to shutdown production. Currently, we are currently using an ultrasonic meter. Although it's a good instrument, the water and vapour contents make it difficult to give us true readings. The device trips (shuts down) whenever vapour or water is beyond a certain value. A positive displacement meter such as a turbine or oriffice meter would be great, but the situation is such that a shutdown is out of the question. Does anyone have recommendations or advice? Thank you all very much.
Flow application
08/12/2006 3:14 PM
Without being able to modify the line during an outage, your options are quite limited, as you well know. Your best bet is to contact an engineering representative for one or more of the various instrument manufacturers.
You can search these out using globalspec. A couple of familiar companies:
Emerson Process Management's Rosemount
http://www.emersonprocess.com/rosemount/products/f low/index.html
Endress + Hauser
http://www.endress.com/
A useful beginner's introduction to flowmeters:
http://www.flowmeterdirectory.com/flowmeter_for_be ginner.html
The legacy of the digital age is that of segregation through differing formats. - HerbVic
Turbine meter
08/14/2006 9:11 AM
Consider one of those paddle wheel turbine meters. They can be hot tapped without shutting down the system. Being a point measuring device, they will not be as accurate as an ultrasonic meter.
I assume you are using a rate of transit ultrasonic meter which measures the time it takes for an ultrasonic signal to travel upstream versus downstream. Consider a doppler ultrasonic meter. Essentially they measure the speed of particles in the fluid to calculate flow. They are not so good for clear flow, however entrained bubbles would serve as particles.
Re:Turbine meter
08/16/2006 9:37 AM
Since two months we are testing the new ultrosoncic flowmeter Nivusonic from the company Nivus (http://www.nivus.com)in parallel operation with a standard insertion transit-time-flowmeter. The sensors are mounted on the outside of a 1000mm pipe. The medium is wastewater. This system combines a transit-time method with a "Doppler"-method. If the concentration of bubbles becomes to high, the system can switch to velocity measurement of the particles with the "Doppler"-method. Up to date the results are very satisfying.
Re: Flow Meter
10/06/2006 12:02 PM
Spartek Systems out of Canada
Anonymous Poster (1); HerbVic (1); Howetwo (1); joerg (1)
You might be interested in: Gas Flow Meters, Flow Meters, Paddlewheel Flow Meters
