Dear all
please suggest me the way,
at present i m using stiller (battery opertaed). but it is not working, so we are doing nothing work from it. so i want to change it with rectifier
i m decided to change the battery & convert it into rectifier type.
so that i can just put the material on it & take it to the top floor(3000mm) above.it is not moving stiller. but we use it on a single place.
at present
i m using 02 nos. 12 v battery (series) operated, 180Ah,25 plate & 6 cell
our pump is d.c. voltage (24v) driven & 250 ampere of controller is available
can any body tell me what type of t/f, rectifier, & diode i use to overcome this problem.
i don't know the rating of pump.
i will be very thankful if any body can explain it bia diagram
or any further suggestion & or quary is welcome
SAHIL SHARMA
