Previous in Forum: Alarming Open-Source Security Holes   Next in Forum: J type k type
Program reset on Dolphin Pool Caddy
05/28/2008 10:47 PM
Does anyone know of a method to reset the program in a Dolphin Diagnostic Pool Cadddy 3001 which had a motor failure on the main module, repaired same but the unit stays in the self test mode now and will not continue in main program. Programming advice is unattainable from original mfg/seller and no software is available as they disclaim any liability or knowledge of the product. The unit completes self test operation and stops although power is still being applied to unit. Power must be turned off and back on then the unit will restart in self test mode and stop again?
Thanks for any help.
