Previous in Forum: BP Learns From Pigs in a Pipeline   Next in Forum: Everything About Compound Cylinders
EDS Maglev System with Coil in Guideway
08/12/2006 12:15 PM
Robert Neitzke writes:
In an EDS Maglev system with a primary coil in the guideway and permanent magnets in the vehicle, is the horsepower or newtons per second accumlative as the speed increases? How would this look on a graph (HP vertical vs. 0 - 300 mph horizontal at 5 to 10 hp per foot)? Now, add the aerodynamic drag of a typlcal minivan graph line. Now, add a graph line combining all these factors and any other losses.
Hmm.
08/13/2006 11:21 PM
My guess is that any leviation related power consumption would be due to resistive loss in the induction magnets on the track. You might treat it as a static electromagnet to estimate the power consumption. Other forms of work done by or on the field would be electromagnetic radiation- no idea of the scale tho, or magnetic fields induced in other bodies. Otherwise, pushing it through the air will be like pushing anything else through the air, power needed is proportional to the velocity cubed.
Maglevs in vacuum tubes?
09/08/2006 8:31 PM
I hear that many proposals have been investigated, to establish the feasability of Maglev 'shuttle trains' to 'fly' down evacuated tubes, possibly reaching ten times the speed mentioned; 3000+ mph? Also power requirements would be closer to the square, not cube of velocity.
"Neither man nor woman can be worth anything until they have discovered that they are fools. The sooner the discovery is made the better, as there is more time and power for taking advantage of it." William Lamb
Permanent Magnet Maglev
09/08/2006 8:40 PM
In the aforementioned 'Vacuum Tube Maglev Train', Permanent magnets may prove more suitable than all electromagnet. Permanent magnets could also act as dynamic power recovery brakes. The incoming train could transfer a large proportion of it's potential braking energy, to power the accellerating outward bound train.
