Previous in Forum: lpg convertion   Next in Forum: Query on SAE automotive certification
Jeep GC chuckle
05/29/2008 9:38 AM
Just to see if anyone really knows, I have a 2001 Grand Cher, Laurado, that gave a DTC set of 442, 455, and 456, all leaks in the EVAC system. Reset and drive gave DTC 442, so I changed caps, and ran the lines and electrical. Still have 442, so I'm asking for ideas as to what I'm gonna find. Guessing it's the LDP(hopefully), as it's the cheapest to replace.
Thx
BillRata
Waiting on registration mail, show showing as guest right now.
Re: Jeep GC chuckle
05/29/2008 10:16 AM
DTC?
EVAC?
LDP?
NBG!
Re: Jeep GC chuckle
05/29/2008 12:19 PM
Oops, sorry.
DTC is diagnostic code from the car's computer.
EVAC is evaporative emmississions control (fuel built up in tank, lines, etc.
LDP is the leak detection pump
Thx,
Billrata
If it's wrong, tell me what's right.
Good Answers: 97
Re: Jeep GC chuckle
05/30/2008 12:50 AM
replace filter
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
Re: Jeep GC chuckle
05/30/2008 1:55 AM
I have a brother who had a Dodge Ram (Chrysler product like the Jeep) and had multiple DTC's related to the EVAC. I can't remember what was all wrong, but there were some leaks in the rubber hoses, as well at the canister which captures the vapor.
I understand these are common problems with these systems.
Speak softly and carry a big stick.
Re: Jeep GC chuckle
05/30/2008 3:35 AM
Remove the radiator cap, slide a new car underneath and refit cap!
Re: Jeep GC chuckle
05/30/2008 10:21 AM
Good morning:
I had a similar problem on my wife's 2001 Voyager. The repair shop did a smoke test and found nothing wrong. They reset the computer and told me if it reappeared I'd have to replace the computer. I found a small cut on the gasket of the fuel filler cap, but that wasn't the root cause. I purchased a DTC reader and logged the code each time the check engine light came on. Generally the same code, very small or small EVAP leak.
We began to notice that the check engine light came on within a few hundred feet of the same place as my wife drove to work. A web search found that there is a small pump which cycles when the engine is started to clear the system of gas fumes. If the vacuum pump doesn't pull down far enough it assumes there is a leak and flags the check engine light.
I looked for the pump (to see if had a cracked housing or loose fitting and found several small cracks in the rubber hose at the test fitting the tech used to run the smoke test. I replaced the hoses (cost of $2.00) and the problem has not returned.
All that said, look for small cracks in the rubber hose of the EVAP system and for loose fittings.
Regards, PeteG.
Re: Jeep GC chuckle
05/30/2008 12:34 PM
ok well i have this problem on my dodge car and we found it
upper filler neck on gas tank had a rust hole and caused the error
Anonymous Poster (4); billrata (1); bwire (1); standarded (1)
