For Air normal conditions are 0°C, 1 atm, 0% humity... so sure there will be some change for level sea conditions, you can use a chart for it you can't find it
Thank you for your mail. This question arose because we are designing a system using a submersible air drven pump. This pump will be used on board an FPSO - Floating, production, storage and offloading vessel. The vendor of the pump states that it has an air consumption of x mtr3/hr. My boss wants to know whether this is measured at STP or NTP. Is it all that significant a matter?
Where is your FPSO? If it is in the bay of Nigeria, then the difference between standard conditions of 0 C and the normal day time temp of 35 C is probably significant.
You can look at this article for more info on the conversion.
