Previous in Forum: Can a 460Volt 60Hz 250Hp motor from USA work in New Zealand 50Hz 415Volt?   Next in Forum: 20MVA ,10MVA power transformer
9 comments
Power Problem
06/03/2008 11:11 PM
Hello all, I am new here and find this site very helpful.
I have a small problem and hope y'all can help.
I am tasked to come up with the required KVA to support instruments that have a total amperage of 6 amps in our ASU plant in PNG.
How do I calculate the required KVA?
Re: Power Problem
06/03/2008 11:23 PM
Re: Power Problem
06/03/2008 11:24 PM
Welcome Guest,
If you like this site, i wonder what stops you from registering...
anyway you have not provided a very important input, and that is voltage....
you need kva so volts as well as amperes have to be known....right...
He must be very ignorant as he answers all the questions he is asked. Voltaire
Re: Power Problem
06/03/2008 11:54 PM
I forgot to sign in is all.
Re: Power Problem
06/03/2008 11:56 PM
DID YOU GO ALL THE WAY TO THE BOTTOM OF THAT WEB SITE??
FORULMAS THERE
Re: Power Problem
06/03/2008 11:57 PM
KVA Rating = Voltage x Current
consider 10 amp insted of 06 amp for factor of safety
Re: Power Problem
06/04/2008 12:02 AM
UNDER POWERING DEVICES CAUSES THEM TO HEAT UP AND SHORTEN THEIR USEFUL LIFE. We always supply extra to prevent that damage.
Re: Power Problem
06/05/2008 7:43 AM
Hi
The method to calculate depends on what is the end use
but for all that we can do is list down all the equipments those are to be powered
Make an Excel sheet and write down in column 1 the name of the equipment
column 2 the voltage for the equipment
coumn 3 the average current
column 4 the Peak current ( starting current in case )
column 5 the Surge current as specified in the operations manual
Column 6 the Power factor
Column 7 now calculate the continuos power required using Average Current (V x A x pf)
Column 8 Caluculate the peak power using the Peak or surge current as the case may be but use whichever is maximum
Now you would get two results one which would help you to design your Power requirement along with the trip setting details and other for continous opeartion giving you details of the HVAC and other requirements.
Trust this would help you.
Hobbies - Musician - New Member Hobbies - Car Customizing - New Member Hobbies - Target Shooting - New Member Engineering Fields - Power Engineering - New Member
Re: Power Problem
06/05/2008 6:55 AM
We need more input. 6 amps at 5v or 6 amps at 13.2KV. It makes a wee bit of a difference. What kind of loads are they? Poor power factor inductive? or closer to unity resistive or somewhere in beween?
Re: Power Problem
06/06/2008 4:05 AM
Thanks, you all for the your replies to my problem.
With your help I have sorted it out - I will be using a 3kVA UPS (10 Amps) to keep the instruments up and safe during power cuts.
Thanks all and I look forward to your assitance in the future.
jonjon
Anonymous Poster (1); chaterpilar (1); dadw5boys (4); IanR (1); jonjon (1); STChoudhary (1)
