Previous in Forum: Suction pipe from fountain pump to pool   Next in Forum: cosmic rays
12 comments
Philippines - Member - New Member Engineering Fields - Control Engineering - New Member Engineering Fields - Instrumentation Engineering - New Member
How Come?
06/11/2008 11:58 PM
"Autobots.......TRANSFORM!!!!" -- Optimusprime
The Engineer
Good Answers: 129
Re: How Come?
06/12/2008 12:57 AM
The trick is that the green triangle and the red triangle are not similar. So the two different configurations above are actually triangles with different areas, which is why the blank square appears. The reason the two triangles have different areas is because they have different angles because as I said above, the red and green triangle are not similar, so the angle at the apex when the green triangle is there is not the same angle at the apex when the red triangle is there.
To see this, start from the point on the left for each triangle and go five full squares. Now go up. The top triangle is less than two full squares in height at this distance, but the bottom triangle is exactly two full squares in height at this distance. So you see, although they look the same, they are actually different triangles.
Good Answers: 54
Re: How Come?
06/13/2008 12:25 AM
Roger. This just the sort of tendentious reasoning that I'd expect from someone who's trying to cover up the worldwide Cosmic ray/Pyramid conspiracy.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Good Answers: 247
Re: How Come?
06/13/2008 11:14 AM
I can see from this post that you are one of the cognoscenti. Therefore, I will entrust to you a few details on an over-unity generator Europium and I worked on not too long ago. It is based on precisely the geometry of this puzzle. I would post details right here, but am concerned that perhaps those details could fall into the wrong hands (Roger's for example). Therefore, I am instead providing this link, with the warning to the non-cognoscenti that following this link will cause your teeth to fall out, or worse.
The Engineer
Good Answers: 129
Re: How Come?
06/13/2008 11:36 AM
Great, now I have to make you disappear. Let me tell you, being in the inner circle of a world wide conspiracy to cover-up facts that if brought to light would make the world a utopia is hard work. I just get tired of all the misinformation and the cover stories. Sometimes I'm not sure it's even worth it anymore. Then I fly my super secret "faster than light" spacecraft to Paris to catch dinner and a show, fly back home, and watch my holographic tv for a while, and then slip into my rejuvenation machine for a good nights sleep. In the morning I feel refreshed and ready to remove and reprogram anyone who threatens our super secret (and admittedly sometimes arbitrary) world wide conspiracy.
Good Answers: 247
Re: How Come?
06/13/2008 6:32 PM
Given the top-secret nature of the subject matter, I must switch to communicating via symbols:
Good Answers: 247
Re: How Come?
06/13/2008 12:42 AM
Another way of saying what Roger just said:
1. If you look very closely, and use a straightedge, you can see that the "hypotenuse" in the upper picture is concave, and is convex in the lower. Therefore the "hypotenuse" in not really a hypotenuse: it's two sides of a quadrilateral.
2. You can check the slope of the red triangle hypotenuse and the green triangle hypotenuse. 3/8 = .375 2/5 = .4 The upper quadrilateral is therefore larger that the triangle it appears to be, and the lower quadrilateral is smaller than triangle it appears to be. The difference in size is the one unit square "hole."
A while ago, I cut out paper pieces like this and gave them to my kids to fool around with. Even with the pieces in hand the subterfuge is not obvious. A version in wood would make a good coffee table or desk conversation starter.
The Engineer
Good Answers: 129
Re: How Come?
06/13/2008 8:53 AM
Thanks Ken. I was using "similar" in the geometric way, which is why I imbedded the link to its definition when I wrote it in that original post.
Somehow I missed that they are quadrilaterals, which I think is the most intuitive answer, so thanks for the explanation.
Re: How Come?
06/13/2008 7:25 AM
By making re-arrangements of 1st rectangle as shown in the 2nd fig. we can't get perfect triangle.The whole shape does not give tri-angle thats is the fact.
the hypotenuse line of 1st fig. is drawm between the 2 points and it is perfect tri-angle.
but in the 2nd fig it is the connection of two tri-angles such as red and green and this is not perfect straight line. thats y blank space.
but the area of shaded part in the 2nd fig same that of 1st one.therefore 2nd is not triangle.hence u cant make Q why blank?
Good Answers: 247
Re: How Come?
06/13/2008 10:29 AM
It may appear so, but it is not. The "hypotenuse" in the first figure "sags" by the same amount that the "hypotenuse" of the second figure is nudged upward. The best way to verify this is to calculate the slopes of the hypotenuses in the red and green triangles: they are different (.375 vs .4). Therefore, neither the first figure nor the second can be a triangle -- they are both quadrilaterals.
Re: How Come?
06/14/2008 4:38 AM
Or, if you don't have straight edge, or don't want to put one against screen, note where the apexes of the little triangles and hypotenuse (after they moved) do not intersect the grid intersections the same from upper to lower figure, indicating that the wannabe hypotenuses are not following the same paths, upper and lower.
Re: How Come?
06/14/2008 4:42 AM
I meant to say, wannabe congruences. If the hypotenuse of one little triangle was concguent to that of the other, then at both the upper and lower big quad the seeming but not actual big hypotenuse would intersect intersections in the grid at the same points, upper figure and lower figure. They do not.
Re: How Come?
06/14/2008 4:53 AM
Register to Reply 12 comments
Anonymous Poster (3); Bayes (3); Blink (4); ffej (1); viji (1)
