Previous in Forum: 454 chevy temp sensor   Next in Forum: Brake Overheating
Automobile
06/12/2008 12:34 AM
Hello
I want to know why we are adding Oil in petrol for Our two wheeler???
Re: Automobile
06/12/2008 2:39 AM
Presumably it's a 2 stroke engine and that's the easiest way to lubricate the big end, little end and bore.
On a 4 stroke the underside of the piston is force/splash lubricated as it is all exposed to the sump. On a 2 stroke the volume under the piston is enclosed as it acts as the intake volume for the fuel/air mixture before transferring it to the volume above the piston at the lower portion of the stroke.
Some two strokes do have forced lubrication but adding oil to the fuel is still a common way of lubricating.
Some of this oil gets burnt of course which is why 2strokes produce more smoke/pollution/characteristic small that a 4 stroke...
Good Answers: 97
Re: Automobile
06/16/2008 12:00 PM
So the oil in the fuel doesn't lube the crank/connecting rod bearing, yes/no?
Re: Automobile
06/16/2008 12:18 PM
I said "Presumably it's a 2 stroke engine and that's the easiest way to lubricate the big end, little end and bore."
The 'big end 'is the 'crank/connecting rod bearing' ... so that would be a 'yes'
The 'big end' is the 'big end of the con-rod' ...
The 'little end' is ...yes you've guessed... the 'little end of the con rod'
Or aren't these expressions used in the US?
Good Answers: 97
Re: Automobile
06/16/2008 1:04 PM
Yes in vertical orientation
