Previous in Forum: Star Point Grounding of Neutral -220kV Primary Side   Next in Forum: angle demand
soft starter synchroniser (for a synchronous wind turbine generator
06/12/2008 4:52 AM
whats is the essence of starting a 48pole 240v synchronous wind turbine generator with the help of a soft start. what is the role of the soft start.
Good Answers: 804
Re: soft starter synchroniser (for a synchronous wind turbine generator
06/12/2008 2:11 PM
Accelerates the generator as a motor using the amortisseur windings, but reduces the stress on the grid connection in doing so.
Typically a wind turbine's blades are designed to slip off a lot of energy when standing still so as to not damage the windmill when shut down or in high winds. So it cannot create enough torque from a dead stop to accelerate it. The mill must be accelerated by using the generator as a motor, then once it gets to full speed, the wind torque takes over to keep it turning and then generating.
In a synchronous machine, the amortisseur winding is a separate winding of the stator that allows it to run as a squirrel cage motor, solely for the purpose of acceleration from a stop.
