Previous in Forum: Bandsaw wheel bearings   Next in Forum: It's possible to clone petroleum ?
don
06/15/2008 7:07 PM
I have a riding yard machine 18 hp that starts great when the engine has not
been running for about 6 hours. but if the engine is running and I shut it off
the mower wont start for a min of 6 hours
Have fresh gas in it
new plugs
need to know what to look at next
and how to test for what is recommended.
Re: don
06/15/2008 8:22 PM
Sounds like maybe it is getting flooded... or maybe starved... Try pulling the plug and letting it air out and see if that helps. At the same time check to see if the plug is wet with gas.
Also have a look at all the parts along the fuel line, especially the float bowl. make sure there are no cracks and that everything is working ok. I had a cracked float bowl once that would draw enough suction to get gas from the tank, get the engine started, and run, but then it leaked so bad it did not run very well....
Reply to Forum Thread
