Previous in Forum: It's possible to clone petroleum ?   Next in Forum: Cheap PV Panels
Presurized Systems
06/15/2008 10:13 PM
I'm trying to establish at what pressure would an owner consider ASME B31.3 piping to be classed as "High Pressure"?
The piping is not carring a dangerous fluid.
ASME has come out with another high pressure piping code which starts at 10,000 psi. would it be logical for a well designed system operating at less than 10,000 psi not to be considered as high pressure piping?
Pathfinder Tags: construction Pipe piping
Re: Presurized Systems
06/15/2008 11:54 PM
read up on catagories in B31.3, it defines the fluid type first. Next, what different does it make, once the pressure is over 1 psig, its covered by the standard.
You might be interested in: Piping Services, Pressure Regulators, Pressure Gauges
