Greg Purnell writes:
We have a sports apparel manufacturing business outside of Reading, PA. About 70 employees, and a niche market of custom sublimated uniforms. We run the materials (fabrics - polyester) over special paper with special ink that at 400 degrees F for about 40 seconds turns into a gas, comes up off of the paper, and permeates the goods, permanently dyeing the ink into the material.
The heat press is a rotary one with a drum about 36" in diameter. It travels about 1' per every 5 seconds around the heating elements inside it. What the problem is is that the belt that goes around the drum sometimes stops due to changes in temperature (like when they turn the machine off/on), and it causes a huge hazard for fire, not to mention the fact that if there is any material in the machine or around the drum, it is burned into the belt, which subsequently ends up transfering onto other pieces that we put through. The entire machine needs to be dismantled so as to clean and/or replace the belt ($$$ for the belt and labor).
We want to put a sensor/detector/switch or something on there to prevent this problem.
Any ideas?
Thanks,
Greg Purnell
