1. Wall-mounted butane gas water heater (for all hot water including shower).
2. Coiled black PVC water pipe to heat water directly from sun.
How can I connect the two?
Location: Mountains of southern Spain - so plenty of sunlight.
Finances: Very limited!
Problems I can see so far: If I simply connected the output from the solar-heated tubes to the input of the butane gas water heater then I will get hot water but it will not stop the gas from igniting as there is no heat sensor. If I connected it directly to the taps/shower and by-passed the butane gas heater, then I would only get cold water at night and when the sun was not shining.
Any ideas?
Thanks
Joe
