Hello, I'm running RSVIEW32 Webserver in conjunction with PLC's and heat sensors, in order to allow anyone in our plant to monitor different temperatures of our Industrial air compressors. The problem is that I noticed that RSVIEW32 defaults to a screen resolution of 1600 x 1200 which has resulted in an image much to large to display all the data at once on our company's standard computer screens. I know that if you use the command /U &width=N=&length=N that you can change the size yourself, but I was wondering if there was a way to change the default screen size so that people with less time and computer experience wouldn't have to actually fumble around with changing the screen size on their end.
Thank you.
