What is the best way to tap M3 in s/s 316 15mm deep, was told by tap suppliers to use blue ring spiral flute tap while an engineering firm that i spoke with said i should use a multi stage tap set, i'm asking because my blue ring spiral flute tap broke off half way through the last of 9 holes, there was no sign of hardening eg blue chips, drill was cold and lots F.E.W lube
