Good morning;
Have recently installed a 3gpm instant how water device which runs on LPG.
All the supply lines (gas/water) are as specified by the manufacturer, however the unit has a very narrow (gas/water) setting (s) before ignition will take place (battery). Any variation from these settings (either gas or water) results in a near explosion--Have pleaded with the manufacturer on a fix for this situation but all I get are "change batteries,reduce gas level,increase water volume" ,all of which had been done several times--I was able to finally reduce the water volume and lower the gas volume to mininum and obtain consistant ignition--
My problem now is that the water tempature must rise in the unit immediately following "shutoff" (time for gas to shut off completly) which has resulted in the "hot water line" supplying the house to blow off--the fitting has actually separated from the line.
I'm using braided ss flex lines for supply and delivery lines aproxametly 20" long from the unit to their respective pvc lines. The hot water line is the one separating--
Is there a "high temp/high pressure" line available to replace this line ?(the cold water side is fine).
