Previous in Forum: Solar Home Back-up   Next in Forum: Marketing Renewable Power
Solar Controller
06/26/2008 6:56 AM
Can anyone help me out?
Can I link 48V solar controllers in parallel into one set of 48v battery system as to achieve the solar panel total Amp input to charge the battery.
Re: Solar Controller
06/26/2008 7:14 AM
My instinct is a big NO.
You'd need to consult the controller manufacturer to be sure...but trying to current share is always dodgy.
Someone may know better ...
11/29/2012 2:47 AM
dear friend,
we are professional manufacture of solar controllers since 2005 year.
Any question, pls kindly let me know
06/26/2008 3:53 PM
Another No here. Unless the controller manual specifically says that it can support parallel operation then you may find yourself with a rather expensive smokey-smelling doorstop (or two).
You are better off sticking to using a single larger controller (your basic non-grid connected regulators are cheap enough anyway, even in large capacities).
11/29/2012 3:03 AM
yes, my friend. U can connect the controllers in parralel to the battery, and it is the normal connection way. By connecting the positive pole of solar controller to the positive pole of the battery, and by connecting negative electrode of your controller to negative electrode of your battery, that is the normal connect way. so no problem, my friend
Register to Reply 4 comments
jack of all trades (1); John chen (2); user-deleted-1105 (1)
You might be interested in: Solar Water Heaters
