Previous in Forum: DC TRACTION MOTOR HELP?   Next in Forum: Substation GPR Questions
reducing starting amps on 12v dc motor
07/01/2008 6:22 PM
can anyone tell me how to reduce starting amps on of 12v dc motor .( cap maybe? its a fuel pump on a racebike with constant loss setup .
Re: reducing starting amps on 12v dc motor
07/01/2008 9:06 PM
I believe that using a cap would actually increase your loss. You first would need to charge up the cap before starting the motor. Why do you need to reduce the starting amps anyway? Does it draw too much current at start and you are using a small battery?
Perfection is achieved, not when there is nothing left to add, but when there is nothing else to take away
07/04/2008 10:51 PM
YES IAM USING VERY SMALL BATT NO MEANS OF CHARGING. VOLTAGE MONITOR TAKES A DIVE UPON STARTING OF COURSE LEVELS OUT . IT EVEN SPIKES ENGINE MANAGMENT WHEN BATT GETS ALITTLE LOW. THANKS
07/03/2008 1:07 PM
A negative temperature coeffient resistor (NTC) will reduce the starting current.
If selected correctly it has a high resistance at motor start, heating up by current flow, this reduces the NTC resistance, which increases the current.
If further information is wanted, state current when running, motor DC resistance und starting voltage (from external source)
Schorschimi
schorschimi
07/04/2008 11:03 PM
THANKS ID LIKE TO GIVE IT A TRY RUNNING AMPS 3.5 MOTOR RES,18.5 STARTING VOLTAGE 12.VDC STARTING AMPS 8
Anonymous Poster (2); schorschimi (1); Shawn_V_Elect (1)
